Re: No cool at idle and smoke
Posted: Sun May 10, 2020 3:13 pm
Thanks for the link I went ahead and put a new evaporator in So the only thing I need to flush is the lines. I am going to use brake clean.
https://autoacforum.com/
Please don't! Well at least don't blame the compressor when it fails on you. IMOazlincoln79 wrote:Thanks for the link I went ahead and put a new evaporator in So the only thing I need to flush is the lines. I am going to use brake clean.
Yes, indeed...I think ice-n-tropics nailed it.ice-n-tropics wrote:Probably oil and refrigerant release onto exhaust manifold from PRV pressure relief valva due to overcharge of oil and/or refrigerant.
hotrodac
Correction: ...weigh-in exactly 42 ounces of R-134a.JohnHere wrote:Yes, indeed...I think ice-n-tropics nailed it.ice-n-tropics wrote:Probably oil and refrigerant release onto exhaust manifold from PRV pressure relief valva due to overcharge of oil and/or refrigerant.
hotrodac
Taking the other recommendations into account, you'll need to start over with the system completely empty of oil and refrigerant, then re-charge both to spec. If the new compressor will take 6 ounces of oil, then distribute the rest of it to the new condenser, the new evaporator, and the new receiver/dryer--1-1/4, 1-1/4, and 1/2 ounces respectively. Then, evacuate the system well and weigh-in exactly 40 ounces of R-134a. The small cans often contain more or less than 12 ounces (in this instance, probably more) since the PRV released refrigerant and oil all over the place due to excessive pressure on the high side.
