No cool at idle and smoke
Re: No cool at idle and smoke
Postby bohica2xo » Sun May 10, 2020 2:20 pm
azlincoln79
Postby azlincoln79 » Sun May 10, 2020 3:13 pm
Thanks for the link I went ahead and put a new evaporator in So the only thing I need to flush is the lines. I am going to use brake clean.
ice-n-tropics
Postby ice-n-tropics » Sun May 10, 2020 3:28 pm
PRV rarely resets to original spec and should be replaced due to aluminum fines stuck in the pop off seat.
hotrodac
Postby Cusser » Sun May 10, 2020 3:52 pm
I've flushed new compressor myself.
About 15 years ago I bought a compressor from the board sponsor, for my '88 Mazda truck. It arrived with oil, but a PAG oil (I could determine that readily from a drop of oil in 5 minutes using the infrared spectrophotometer). Since I was still using R-12, I had to flush, and I flushed three times with R-12 type mineral oil and dumped, then added the correct amount. Two months later, my co-worker bought a compressor from the board sponsor for his 1990 Mazda Protege, and that one arrived with R-12 mineral oil.
Postby Tim » Sun May 10, 2020 5:27 pm
azlincoln79 wrote:Thanks for the link I went ahead and put a new evaporator in So the only thing I need to flush is the lines. I am going to use brake clean.
Please don't! Well at least don't blame the compressor when it fails on you. IMO
P:602-233-0090
Postby JohnHere » Tue May 12, 2020 9:50 am
ice-n-tropics wrote:Probably oil and refrigerant release onto exhaust manifold from PRV pressure relief valva due to overcharge of oil and/or refrigerant.
hotrodac
Yes, indeed...I think ice-n-tropics nailed it.
Taking the other recommendations into account, you'll need to start over with the system completely empty of oil and refrigerant, then re-charge both to spec. If the new compressor will take 6 ounces of oil, then distribute the rest of it to the new condenser, the new evaporator, and the new receiver/dryer--1-1/4, 1-1/4, and 1/2 ounces respectively. Then, evacuate the system well and weigh-in exactly 40 ounces of R-134a. The small cans often contain more or less than 12 ounces (in this instance, probably more) since the PRV released refrigerant and oil all over the place due to excessive pressure on the high side.
Postby JohnHere » Tue May 12, 2020 10:02 am
hotrodac
Correction: ...weigh-in exactly 42 ounces of R-134a.
