1992 Buick Roadmaster, R12 to R134a
bgoins12
Postby bgoins12 » Fri Mar 27, 2020 8:01 pm
Hi guys, I am in the process of redoing the AC system on my 92 Buick Roadmaster. I pretty much bought everything I needed (new updated scroll compressor, accumulator, orifice tube, seals, etc.), but I didn't realize until after getting my stuff that there are different colored AC switches...for both the compressor mounted one and the one on the accumulator.
Since I am converting from R12 to R134a, I have no clue as to which colors I need. At the moment, the new ones I bought are a GPD 1711334 (blue) compressor switch, and a GPD 1711250 accumulator mounted clutch switch (white hex end, black plug end). The 1711250 says "R12" on it, so I assume it won't work with the 134a conversion.
The old switches are yellow on the accumulator and gray or white on the compressor.
Any help is appreciated!
bgoins12
Re: 1992 Buick Roadmaster, R12 to R134a
Postby bgoins12 » Sat Mar 28, 2020 9:56 am
So after a bit of research this morning, I discovered that the difference between all the compressor mounted switches mainly relies on where the keyed slot/tab is clocked on the switch/plug. Somehow I managed to order the correct switch for the compressor, but I am still not sure on the accumulator mounted one.
Correct compressor switch
Al9
Postby Al9 » Mon Mar 30, 2020 2:52 am
Sure you can't find an R134A one? 4seasons seems to have one with an R134A label, code 36674.
