Classic car ac help
Posted: Tue Dec 31, 2019 9:27 am
by Vckline313
Hello all new member and have afew questions. I have a 1972 Buick skylark with factory ac, but when I bought the car nothing was hooked up and the condenser was cut. I have now since put a Chevrolet motor in the car with a late model truck ac compressor and serpentine belt setup.
What would the better option be going vintage air or replacing all factory ac components and getting custom lines made? What all parts do I need to buy? I'm not familiar with ac systems but am fairly mechanically inclined.
Re: Classic car ac help
Posted: Wed Jan 01, 2020 6:56 am
by B52bombardier1
Hello,
I'm happy with the Classic Auto Air conditioning system in my 70 El Camino. This is a total replacement of everything from the original GM / Chevy / Harrison air conditioning system. No more vacuum operated controls in the system - all electric. It uses R134 refrigerant, not R12. I'm quite happy with it.
https://www.classicautoair.com/
Rick
Posted: Wed Jan 08, 2020 2:37 pm
by ice-n-tropics
Vintage Air's book "How to Air Condition Your Hot Rod" explains how to match system component capacities so that the compressor capacity (displacement/swept volume and drive ratio) is not excessive.
condenser energy rejection must match the evaporator heat absorption plus horsepower energy draw of compressor.
The larger the condenser and it's air flow, the better.
GM's use of 30% outside air is a wasteful horsepower draw verses Vintage Air's with 100% recirculated air through evaporator.
hotrodac
Posted: Mon Jan 13, 2020 12:12 pm
by jamyers
Nothing wrong with the Buick evaporator, heater core, and fan per se, assuming yours are in good shape.
Keep in mind that the Buick system used a TXZ and POA, and the newer system uses a Cycling Compressor with an Orifice Tube.
