Purging With Nitrogen ???
Posted: Tue Nov 12, 2019 1:41 pm
by philipswanson
Is it a good idea to purge my A/C system with nitrogen before charging to remove moisture? The lines were flushed and left open a month ago. RV is garaged here in SoCa. New compressor and components were professionally flushed before installation.
Re: Purging With Nitrogen ???
Posted: Thu Nov 14, 2019 5:44 pm
by Miggy
The ac shops here in my place always purge the system with nitrogen before vacuuming the system to charge. The reason, i dont know. But i know that vacuuming the system is what removes the moisture.
Posted: Fri Nov 15, 2019 6:52 am
by Dougflas
Excellent idea to flush with dry N2. This makes for a better vacuum process.
Posted: Sun Nov 17, 2019 12:08 pm
by philipswanson
I think the reason for nitrogen purge is simple. To eliminate moisture from the system which is destructive.
