A/C quit
uninformed
Re: A/C quit
Post by uninformed »
Not finding what I was hoping for.
Here's 3 photos, one showing the fuses, 2 iod and other misc. fuses.
And 2 photos showing the underside of the fuse box which only contains plug connectors.
Dodge #3.jpg (153.17 KiB) Viewed 4622 times
Dodge #2.jpg (142.99 KiB) Viewed 4622 times
Dodge #1.jpg (135.36 KiB) Viewed 4622 times
Re: A/C quit
Bummer. There are a bunch of relays someplace in that truck. I wish Mopar did a better job on electrics. Being known for crappy wiring for more than 50 years is not exactly a good thing.
I have seen the piano box in Rams trucks before, as well as the rectangle. Low bidder on the wiring harness probably changed 5 times in 3 years...
uninformed
Re: A/C quit
It leaves me stymied because even my service manual doesn't mention the word relay anywhere that I've looked and even the numerous diagrams only show the starting point being the TIPM, (Totally Integrated Power Module).
And for checking the compressor clutch it says if the fuse is OK the next step is use a scanner tool.
