Might need NEW Sanden SD708 Model 7225 compressor
I might need a NEW Sanden SD708 Model 7225 compressor or other clone you have confidence in, not a remanufacture/rebuilt. I bought the current SD708 Model 7225 from you at Arizona Mobile Air at the Clarendon location October 2014, and it appears to have a leak in the compressor body seam, at the rear. Today I tightened the bolts holding on the rear housing a little, but don't know how optimistic I am. So might need a source for such compressor, takes a standard (non-serpentine) belt; this is for my old Mazda truck. Still R-12 as well.
Since I also have a 1998 Frontier with great AC (just removed an AC clutch shim a few weeks ago), I may hold off on such compressor replacement until fall, as it's 112F here in Phoenix today. Thanks.
Re: Might need NEW Sanden SD708 Model 7225 compressor
I'm sure I can help. It's a call item. Hit me up in an email and I'll check Monday.
