Quality can tap?
PromiseRing
Quality can tap?
Post by PromiseRing »
Hey everyone. I've been doing some AC work in the past and have yet to be satisfied with any can taps I've used.
Before the self sealing cans came, I have a tap that simply punctured the top of the can. It worked okay.
Then the self sealing cans came, and the blue adapters came out. Those suck, I could never get them to work well.
So I bought 2 new can taps from oriellys / advance auto, both of which are supposed to be used with the self sealing cans.
The problem: they simply do not allow refrigerant to flow easily. After installing them onto the cans, there's an *extremely* small window in which refrigerant can flow through. (For example, I'm turning in the dial and I hear the pressure leave the can into the gauges, but even 1/16 of a turn past that, all flow stops).
Needless to say, this is a major delay in the amount of time it takes to charge systems.
I am looking for a tap that will allow FULL flow like it's supposed to. Is my only option a side tap? Are there quality taps that screw on? Thanks in advance.
Re: Quality can tap?
Side can taps ROCK. My only choice for stuff in cans.
https://www.ackits.com/side-mount-can-t ... 0can%20tap
Reliable, easy to use. Works on all of the standard size cans. Ever drop a nearly full can of brake cleaner, and snap off the valve stem? Yep, works for that too.
PromiseRing
bohica2xo wrote:Side can taps ROCK. My only choice for stuff in cans.
Awesome, thank you!
The item listed is no longer available.
Same thing fr5om different vendor. Little better quality.
https://www.ackits.com/side-mount-can-t ... rch=MT1036
Thanks Tim, I will update my bookmarks.
That IS a better unit. Both fittings and the adapters stay with the unit - Nice!
bohica2xo wrote:Thanks Tim, I will update my bookmarks.
You know the game. Vendors always swapping brands and increasing prices. Everyone has a knock-off to offer which is good sometimes. For tools and such. Still try and stay with Mastercool or Santech.
Just a notice. The developmental site for parts is up and running. Should be some fair prices on compressors and such.
http://www.ackits.net
