Cheap & Effective Flushing
KrossT on Sat September 21, 2013 10:49 PM User is offlineView users profile
Year: 93
Make: Honda
Model: Accord
Engine Size: 2.2L
Ambient Temp: IDK
Pressure Low: n/a
Pressure High: n/a
Hello all, I've heard nothing but exceptional things about this forum and thought I would seek advice.
I have ordered a BNIB Denso a/c compressor w/ clutch, 4 season drier/receiver, 4 season expansion valve, all new seals, and generic condenser for the a/c job I will undertake myself in the following month. I am mechanically inclined and will be doing everything myself.
Since I am removing all my components ( hardlines, softlines EVERYTHING ) What would be the best method to flush all of the disassembled lines without buying 40-50$ A/C flushes? ( I am trying to avoid this excessive expense if it can be done thoroughly another way ) Does anyone know exactly the ingredients in A/C flushes?!
Would a heated pressure washer do a thorough job? I've seen a few random forums suggest paint thinner, gasoline/ethanol, or mineral spirits, but heard those methods discouraged because of residue or contaminants left behind by those methods.
What would be the best brand refrigerant as well?
I will monitor responses to this post. Thank you very much ahead of time!
Edited: Sat September 21, 2013 at 11:09 PM by KrossT
TRB on Sun September 22, 2013 11:26 AM User is offlineView users profile
Hecat Safe flush is what we use.
Power washer would add moisture to you system.
KrossT on Sun September 22, 2013 12:00 PM User is offlineView users profile
Hecat Safe flush 164$ for a gallon NOOOO THANKS!!! My title says "CHEAP & Effective". Im not looking to spend more than what my Denso compressor costs on flush solvent alone.
If moisture is the only concern, then I honestly dont think it would add moisture if I left the lines to dry 72 hours AFTER blasting them with compressed air for 10-20 minutes??
Edited: Sun September 22, 2013 at 12:11 PM by KrossT
TRB on Sun September 22, 2013 12:16 PM User is offlineView users profile
$43.00 per gallon and it is a lot cheaper using the correct products then redoing it over again and again.
Good luck with the power washer.
Hecat Safe Flush
Edited: Sun September 22, 2013 at 12:19 PM by TRB
HECAT on Sun September 22, 2013 2:19 PM User is offline
Did you read this?
Back to Automotive Flushing Forum (Supported By Hecat Inc.)
