video of H1000 in operation
samjesse on Sat December 25, 2010 11:05 PM User is offline
Hi
Can you please post a link to a video of the a/c flushed H1000 being used in actual automotive a/c flushing?
thx
TRB on Sat December 25, 2010 11:09 PM User is offlineView users profile
Google or Bing is your friend.
http://hecatinc.com/product_videos.htm
samjesse on Sat December 25, 2010 11:24 PM User is offline
I have seen this H1000 "marketing" video". That was not what I was after. Do you also have a user guide I can download? thx
Edited: Sat December 25, 2010 at 11:24 PM by samjesse
samjesse on Sat December 25, 2010 11:47 PM User is offline
Is H1000 used as a closed loop on the automotive a/c system? or closed loop on each "separated" component of the system?
HECAT on Sun December 26, 2010 9:21 AM User is offline
All we have at the moment is the video you have seen. The H1000 is a closed loop system that is usually attached to the isolated condenser circuit and then a second flush is needed for the evap circuit. Complete system flushing is not recommended as contamination removal will be hindered by the blowing of junk from one heat exchanger to another. However, for oil removal only (no debris, no compressor failure) a complete refrigerant sweep of the system can be done.
TRB on Sun December 26, 2010 11:22 AM User is offlineView users profile
Karl, 3 out of the 6 videos are missing on that page.
HECAT on Mon December 27, 2010 8:54 AM User is offline
You are correct Tim. Sorry for the inconvenience.
Video edits and web re-postings are currently in process.
TRB on Mon December 27, 2010 10:55 AM User is offlineView users profile
Not an inconvenience just a heads up in case you did not know.
Back to Automotive Flushing Forum (Supported By Hecat Inc.)
