COMPRESSOR FLUSHING
yorled on Mon July 12, 2010 11:06 PM User is offline
I have an ac compressor which was using R12 oil and refrigerant but,now,I would like to use said compressor in a system which uses r134a oil and refrigerant. The question i would like to ask is if it's ok to use r134a oil to flush this compressor which was using r12 oil?
Thanks in advance!
yorled on Mon July 12, 2010 11:44 PM User is offline
Will the seals be compatible with the new application?
iceman2555 on Mon July 12, 2010 11:50 PM User is offlineView users profile
What type compressor is being utilized?
yorled on Tue July 13, 2010 7:34 AM User is offline
The compressor is the valve type.
HECAT on Tue July 13, 2010 11:09 AM User is offline
Originally posted by: yorled
The question i would like to ask is if it's ok to use r134a oil to flush this compressor which was using r12 oil? Thanks in advance!
That is how a "compressor oil flush" is done, rinsing old out with new; no solvents.
HECAT on Tue July 13, 2010 11:12 AM User is offline
Iceman is asking for compressor brand and compressor model number to try and answer this question.
Back to Automotive Flushing Forum (Supported By Hecat Inc.)
