Year: 1995
Make: Chevy
Model: Suburban
Engine Size: 5.7L
I've posted on another forum about my project: "Stumped." Haven't had a catastrophic failure, yet. But, if I open up the system to make the suggested repairs, I figure I might as well flush it out while it's open. BTW, it has rear AC too. Anyway, I've been checking around with shops and dealers for flushing. To my surprise, I called the GM dealer I use and asked what a flush would cost. A red flag went up when the service writer didn't know what I was talking about. She asked me to hold on and was gone for several minutes. When she returned, she said spoke with the AC technician and he said no flushing was necessary. They would evacuate and recharge for $220.00. I said OK and thanked her for her time.
I thought that strange, because I read somewhere that every GM dealer had been supplied a machine, the ACR-2000 to be exact, that was capable of doing a refrigerant flush, as well as the other necessary functions. I've also read the ACR-2000 does not meet new EPA certifications, but can still be used. I would think a dealer would have the latest tool technology.
Called an independent shop. He has a flusher, but it is a closed-loop chemical-type that is being repaired. He did say though that they would do it "old school" by recovery, vacuum, and recharge. It is my understanding that recovery, evacuation, and vacuum does not remove oil and any debris from normal wear and tear.
At another shop, their machine was broken and shop owner was debating whether to buy a new one.
Likewise, in my search around the Northern Virginia area, I haven't been able to find an automotive ac specialty shop.
In regards to the HECAT DIY kit, I have a few questions;
1. Pros and cons to automated refrigerant flush machine and doing it manually with a HECAT DIY kit?
2. I've read the HECAT tech paper on flushing, so if I were using HECAT flush it would clean out the oil and muck despite it not having any chemical solvents or petroleum distillates (advertised as biodegradable, non-toxic)? I have found biodegradable, non-toxic cleaners are not as effective as chemical solvents (in other applications) to clean petroleum- and synthetic-based lubricants and other contaminants.
3. While researching about flushing evaporators, another publication suggest removing the evaporator to flush because if left in the vehicle the flush agent could pool at the bottom, or elsewhere, and even with purging flush could remain in liquid state and contaminate fresh oil. It went further to say that if no catastrophic failure has occurred, then not flushing evaporator was best course of action. The HECAT article is to the contrary. Why is there differing opinions? I for one am not going to tear out the dash to get at the evaporator albeit getting to the TXV in the rear will be a PITA.
4. If you happen to know a great AC shop in Northern Virginia, I'd appreciate the tip.
5. Or given that I haven't had a compressor failure, do I need to flush at all? It has been serviced once since 1995. I had in for a check up in 2K and shop did a recovery, recycle, vacuum, recharge, and replaced oil removed with clean oil.
Thanks in advance.
SeppW
Edited: Sun July 11, 2010 at 4:23 PM by SeppW
So no risk a flush or solvent leaves an invisible residue after complete evaporation/purge that could get rehydrated with a liquid or lubricant and contaminate the oil/refrigerant?
This is the nontoxic, biodegradable product I was referring to: HECAT Safe Flush As stated earlier, when a cleaning agent says "nontoxic, biodegradable," while green sounding, it doesn't perform, if at all.
Edited: Mon July 12, 2010 at 9:21 AM by SeppW
Got it. Thanks.
Disregard, I' ll have to find another method of flush or skip it all together
One more follow-up question. My repair project, a '95 Chevy K1500 Suburban w/rear air, did not have a catastrophic failure, but I'll have to replace the entire front circuit (- the evap), along with compressor. The liquid and suction lines to rear and rear evap are ok, but I plan to flush the lines and both evaps. I can't get the liquid and suction lines disconnected at rear evap and not willing to risk the outcome of disconnecting. That said, it looks like I have to flush the rear circuit through the suction line forcing the flush from the flare connection in the engine compartment. I can remove the TXV and attach a drain hose off the liquid line outlet from evap. Removing the TXV allows the the liquid line to be flushed by itself.
If using the HECAT DIY kit, I'm assuming there would be enough pressure to clean the length of line and evap? If so, is there a risk the seals would fail after flushing with the safe flush product?
Edited: Mon August 23, 2010 at 9:12 PM by SeppW
The Safe-Flush is compatible with the seals and hose (all elastomers) used in MVAC systems. I am sorry, but I read it twice and still did not completely follow your flushing plan. You cannot flush through a TXV with this Pulsating solvent method, or any other solvent method. Yes, the process uses considerable pressure and pulse energy; but the TXV restriction kills the pressure/energy used for effective cleaning, and also kills the velocity of the adequate "blow" to completely remove the solvent.
The TXV can be removed. I have the old one and drilled it out. But as I said and try as I might, the lines can't be disconnected from evaporator as I am not willing to risk having to replace the evaporator, which on the rear air Suburban means removing the rear HVAC case from the vehicle.
But it it's a moot point now. The pulsator kit is out of stock until maybe 3 weeks. I've got to get this thing back together. I'll have come up with another plan.
OK, got your flush plan; yes you can flush through a long line and the evap with a clearanced flush fixture in place (drilled TXV). I do sincerely apologize. No one is more frustrated at the availability of the Pulsator Flush Gun than me; it's been a real hot summer. Good luck w/ your repair.
