Flushing a compressor (R134 to R12)
MikeC5 on Tue November 10, 2009 12:21 PM User is offlineView users profile
Is there any effective way to flush a compressor that had been used with PAG/R134 to make it ready for ester/R-12? I've let it drain for several days. Should I just pour in new ester oil and hand pump it through? The oil that came out was clean. Any help appreciated.
HECAT on Tue November 10, 2009 1:13 PM User is offline
Mike, you are on the right track. You cannot flush a Compressor with a solvent. You will want to pour in the new oil to rinse out the old.
I would also seek (I cannot answer) a verification that the seals would or will be compatible with your new application.
Here is the tip from the procedure page.
Compressor flushing and testing
MikeC5 on Tue November 10, 2009 1:39 PM User is offlineView users profile
Thank you Hecat. I had read that one a while ago but it didn't sink into the gray matter...
fastsvo on Fri June 11, 2010 3:00 AM User is offline
Does the same apply for going from Freeze12 to R12?
TRB on Fri June 11, 2010 11:01 AM User is offlineView users profile
There is no relationship between refrigerant type and how a system should be flushed. Bottom line follow Hecat's tech paper procedures and one should be on the right track.
Back to Automotive Flushing Forum (Supported By Hecat Inc.)
