Year: n/a
Make: n/a
Model: n/a
Engine Size: n/a
Refrigerant Type: n/a
Ambient Temp: n/a
Pressure Low: n/a
Pressure High: n/a
Country of Origin: Japan
I have a little leak on my ac line so I would like to know if there is any bonding agent that i can use to stop the leak, that would have prevented me from going trough the trouble of pulling so many things to get it weld.
My suggestion is to fix it correctly the first time.
If the line is accessible and not corroded you can try recovering the refrigerant and using aluminum braze to seal the line without removing it from the car. Be very careful though, make sure that it does no attach to a flexible rubber line close to where you are brazing or you will damage the rubber.
Whatever you do, don't use A/C "Sealers" in a Can, they are proven to cause problems.
If the leak is on an aluminum component and is very small (not an o-ring) I will recommend a product called Alum Bond. It is two different tubes of product that is mixed and applied to an aluminum surface.
