Year: 1994
Make: jeep
Model: grand cherokee
Engine Size: 6cyl
Refrigerant Type: R-134a
hi I have a 94 zj 6cyl 4.0
I just changed my heater core and in the process I had to disconnect the a/c lines going to the a/c evap in the firewall.
I finish the job but i had to get some green 0-rings to replace the ones on the a/c lines my question is since i dont have enough money for the
PAG oil is there a alternative i can use to oil the o-rings with?
And just to be sure to re-connect the lines do i need a tool like the one i use to dis-connect them?
Nylog Blue
Ok I cant find the nylon blue but through reading online i see alot of machanics use a light smear of mineral oil or dielectric grease
to lube the o-rings for the lines....
question.
Can i run my defrost without getting the compressor oiled or recharged
