Year: 2010
Make: chev
Model: cobalt LT
People,
Fan speed switch only responds to #4 position, AND blower motor screeches like madly loud. Sounds like bad bearing in motor, right? AND, I have a bad resitior for the dead 1,2,and 3 speeds, right?
If so, can anyone advise a new motor for my car from AC Kits? Bought one there before for another of my cars, and was happy.
beware of the arrival
hOW DOES ONE CUT OUT THAT BLOWER MOTOR? Do you slide a utility knife's blade up in that narrow slit of plastic and cut the molded plastic out? Also, the elec connector wont pop out, seems theres a blue tab which may be locking it in. Must I pull out that tab? 2 wires are in front of the tab preventing the tab from sliding outward.........
OK, hack sawed out the motor, and now it works fine (plugged it in, works smoothly but only on knob position 4, no bearing screech). Also, pulled out the resistor, and motor runs on 4. Can a motor run without the resistor in place? Then, I popped resistor back ion and still, motor runs only on 4. Bad resistor for sure?
Mystery remains, why motor screeched in place, but when removed, no screech. No obstructions up in the evap housing.
If mine, I'd replace both the blower resistor and and the blower motor.
I'm more than surprised that you "had to" cut stuff for access. Did you use a repair manual?
Keeps us using our heads, I guess.
Regards.
