Year: 1990
Make: chevy
Model: astro
Engine Size: 4.3l
Refrigerant Type: r134a
hi, this post is addressed to all forum members. what is your opinion on in line filters? I've read both pro and con about installing. do they leak after awhile? whats your opinion.
Hi Archie,
My opinion. If you have debris, the system needs a flush, not a filter. If you are concerned about debris after flushing, you need a better flushing method, not a filter.
hi hecat, I think the premise is that you never get all the debis out, and so the filter catches whatever is remaining. my question was, are they reliable as far as leaking, etc.
I'm NOT an AC pro. But I'd say that if you had the system apart and were considering adding a filter, might be a possibility.
But - myself - I would never open up an already working system to add one.
I've used them to fix leaks in rear liquid lines- just cut out the bad spot and insert the filter- as a splicer, works everytime if mounted right.
what is meant by "if its mounted right". is mounting it complicated?
Clean cuts with a pipe cutter, clean non-corroded pipe to seal on, not-under torqued, and not over torqued compression fitting- pipe must be straight where cut- no curves or bends. Swageloks for aluminum work better for unions (splices)
what are swaglocks? where can I buy them?? what size? thanks.
I get them off Ebay- 3/8" for liquid line, 5/8" for suction lines-- part number ends in "A" for aluminum-- they make all gas types- brass, steel, etc for almost any welder gas applications as well. I bought a lot of $25 for about $80 once-- they can sell as high as $20 just for one. Just google "Swagelok"
Edited: Thu December 17, 2015 at 7:39 PM by GM Tech
It's spelled Swagelok
Everything you need. AS Hecat states, filters is just a back up for a clean system.
http://www.ackits.com/universal-in-line-filters/in-line-filter-kit-38-516-12-dia-tubes-25547
that's what I said.
