Compete new a/c system (new compressor ?? )
sandmanxx on Thu August 20, 2015 7:28 PM User is offline
Year: 2004
Make: Dodge
Model: 2500
Engine Size: diesel
Simple question:
Have complete new a/c system and my new Denso compressor comes with 210cc of "correct type" of pag oil (just for those who may ask).
Question is can I leave all oil in the compressor and pull a vacuum / pressure test / then vacuum again and charge??
ie: charge high side after vacuum / followed by finishing on low side / etc / etc.
Manual states 180 cc is a system "fill" put does not talk about compressor at all.. States XX oz in evaporator / condenser / accumulator !!
sandmanxx on Fri August 21, 2015 1:22 AM User is offline
total 180cc
accumulator 2 oz
condenser 1 oz
Evaporator 2 oz
the hidden 1 oz not spoken of is the compressor
went back with my ADHD and looked at the manual again
Jag987 on Fri August 21, 2015 2:44 AM User is offline
Depends. If EVERYTHING else is new, there is no oil in the system. If this is the case, I would drain the extra ounce from it and install. Then pull the vacuum, check for leaks and recharge to spec. If any part that the refrigerant passes through is being reused, it will need to be flush first so there is no oil left in it, then drain the extra and recharge. After it has been recharged, but before it is turned on, spin the compressor over by hand a few times. this will help get some of the oil moving. Remember, the compressor is the only part of the system that actually needs oil. But oil moves through the system with the refrigerant so when a part is being replaced, the the accumulator only, 2 ounces in your case would need to be added back.
If you are charging from a 30 pound jug and a scale, you should not have a problem getting all the charge in the high side as liquid. With the 12 ounce cans, the correct charge becomes a bit of a guess.
