Year: 2006
Make: nissan
Model: pathfinder
Engine Size: 4.0
Refrigerant Type: 134
Ambient Temp: 101.1
My 06 Pathfinder compressor stopped suddenly it just wouldn't come on when i started the car. Mechanic simply said it's a dead compressor.
Where do i look first for debris? Second?
Rick
If it was working fine and stopped suddenly, it may not be the compressor. But to answer your question? First, larger pieces will be trapped at the inlet chamber of the condenser. You can back blow the condenser into a clean towel to get a look at what you have. You can also back blow a filter/dryer to see if fines have passed the condenser, and you can back blow the evap to see what fines have made it to or thru the TXV.
