Year: 2008
Make: Dodge
Model: Ram 2500
Engine Size: 5.7
Ambient Temp: 97
Got on the Dodge Forum and based on the other posts it appeared that my condenser fan motor was going out. I noticed that the fan was not spinning, but when you tapped on the motor the fan would start spinning. I replaced the condenser fan assembly but it did not do the trick. Someone told my husband that it was a relay, but 2008's do not have relays. The have a TIPM(I think that is right). Could this be a pressure switch issue? I don't have readings yet, but will go by today and get them. This is driving me nuts! It's hot and humid here in Texas!!
A quick check of the fan and its performance is to hot wire it to 12 volts.
