AC blows warm air
knoxtoy87 on Tue July 21, 2015 2:53 AM User is offline
Year: 2000
Make: Volkswagon
Model: Jetta
I have a 2000 jetta.
Clutch on compressor spins (engages) but ac is warm. I tried to put freon but seems like the compressor is not taking in the freon. Could my compressor be bad?
how would i check the compressor ?
Help, Thank you
GM Tech on Tue July 21, 2015 7:28 AM User is offline
With gages on both high and low side..
knoxtoy87 on Wed July 22, 2015 11:32 PM User is offline
Compressor clutch doesn't engage, what should i check first?
Jag987 on Thu July 23, 2015 2:52 AM User is offline
To see if there is enough refrigerant in the system.
Cussboy on Thu July 23, 2015 9:16 AM User is offline
Since you were apparently confused/unsure about whether your AC clutch was even engaged, I suggest finding an "auto AC" shop in your town; that means not a Midas or Brake-O or some place that just hangs out a sign.
