Refrigerant question
Suberman on Fri July 03, 2015 2:22 AM User is offline
Year: 2007
Make: Subaru
Model: Impreza WRX STI Spec C
Engine Size: 1994
Country of Origin: Singapore
Hi guys,
Is there an optimum level that the I should follow when recharging the air con system? The factory spec says 0.45 to 0.55kg. So is there like an optimum level that I should charge it to? Or is anything in between going to make no difference?
An air con specialist charged mine to about 0.48-0.49kg which seems to be slightly on the low side? If so, will this cause any issues in time to come?
Thanks for any help.
Rgds
Errol
emsvitil on Fri July 03, 2015 4:13 AM User is offlineView users profile
I would fill to .55kg so it would stay in range as long as possible as the refrig slowly leaks out the shaft seal...............
Ed
SoCal
Suberman on Fri July 03, 2015 4:46 AM User is offline
Leak out of the shaft seal? Even if nothing is wrong with the system? Is this something normal? I was under the impression that it doesn't leak at all if the system is fine.
GM Tech on Fri July 03, 2015 7:34 AM User is offline
Doesn't leak at all is a statement made in dreamland-- 65% of five year old+ vehicles leak according to my survey.
Suberman on Fri July 03, 2015 7:57 AM User is offline
Thanks for the info. I was obviously misinformed. In any case, what would you suggest I charge the system to based in the factory spec of 0.45-0.55kg? Is there an optimum range or what's most ideal?
Edited: Fri July 03, 2015 at 7:58 AM by Suberman
Suberman on Sun July 05, 2015 9:46 PM User is offline
So, charging it nearer to 0.55kg would be ideal then?
