Hi my name is Alfredo, I am from Venezuela sorry for my english. I have a Ford Explorer 2006 - 2010 V8 4ta generation, I have a problem with the Blower speed air conditioner, the speed or level 4 of the blower not work, my temperature control is manual. I really dont know use your forum, and I will want post my problem for you help me, How and where can post my problem, I uploaded a video to youtube for some peoples can see my problem.
https://www.youtube.com/watch?v=MKC-hBZqysk
Thank you very much
Check the blower speed resistor normally located right behind the glove box and easily changed.
I bought a new blower speed resistor Original Motorcraft but the problem persist. You can see my video youtube . https://www.youtube.com/watch?v=MKC-hBZqysk
Bad switch or wiring to your blower resistor.
Some versions have a relay that pulls in for high speed only.
If it is the switch, your old one will be rather obviously burnt when you remove it.
Do you have a max setting for your A/C? IIRC, I had a vehicle that the highest fan speed only worked in the max setting.
I think that is the relay bad, because the switch fan is good. I did jumper on the switch fan to speed 4. but only listen one Tick tack from relay, however the blower not work to higher power
I have the manual for a 2009 Ford Escape. The diagram for the manual system which I don't have doesn't even show the actual switch only the resistor inputs to the HVAC module. I believe that module houses all your HVAC controls. The only relay shown is to supply power on one side of the blower motor and the ground is supplied from the HVAC module to complete the circuit.
This one only shows a M-L speed, M-H speed and H speed in the module but the owner's manual shows a 4 position switch. The module is just a block in the diagram.
Edited: Mon June 22, 2015 at 7:42 PM by wptski
Thank for your assistance wptski but I am from Venezuela and my Inglés is very bad , I do not understand so much you tell me. Do you think that the relay is good?
Not sure because the inside of the HVAC module isn't shown so there may be more components.
Yeah, I will buy a new relay, Do you know where find the wiring diagram Explorer 2006 or and diagram similar, temperature control manual.
Be careful looking for manuals because the vehicles sold in other countries may be quite different from the same year make model sold in USA.
Edited: Tue June 23, 2015 at 12:12 PM by mk378
do a google search there is a diagram listed
http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0996b43f/80/21/19/77/large/0996b43f80211977.gif
Edited: Wed June 24, 2015 at 9:56 AM by Dougflas
