Year: 1999
Make: Honda
Model: Civic LX
Engine Size: 1.6 L
Ambient Temp: 100 F
Pressure Low: 30
Pressure High: 185
I recently bought an (unmolested) 16 year old Honda Civic that needed a head gasket. The previous owner told me he replaced the A/C compressor during his 10 years of ownership (since 2005). I replaced the head gasket. The engine now runs GREAT but the A/C center vent temp is VERY high (94 degrees F). The A/C static pressures are LOW: 166 psi and HIGH: 125 psi. I am not sure where to go from here. Any suggestions would be great. TIA! :-) Tim
Edited: Sat June 13, 2015 at 11:01 PM by timothy1959
carefully touch the low side line right where it come back through the firewall and I to the engine compartment. It should be cold. If it is, my first guess would be the heater valve is not shutting off the flow to the heater core causing the cooled air to get reheated. Maybe a blend door not operating properly. Having just done engine work, I would look hard at the heater valve and lines.
The heater valve tends to get out of adjustment. You probably need to move the cable housing where it attaches to the valve to be sure it pushes the valve fully closed when the dash lever is on full cold.
Scroll compressor.
You can't get much of a test at idle. Spin the engine rpm up to 2,000 to 2,500 & record the pressures. Cabin fan on highest speed, doors open.
Post your results & we can go from there.
I tested the pressures again tonight, results = Engine RPM: 2,000, Low Side Pressure: 24 psi, High Side Pressure: 340 psi, Center vent temp: 68 deg. F, Ambient temp: 94 deg. F. TIA! :-)
Go back to what Jag said about the pipe getting cold. The air should be at least as cold as the suction line is.
Are all your engine/condenser fans running?
A condensor issue is most likely, or a bunch of air in the system. 340 psi with a 100f ambient is not good at all.
The condensor air side could be blocked wit bugs/grease/dirt/paint... or the previous compressor could have filled the refrigerant passages with debris as it failed.
I would be inclined to recover the system & replace the condensor, dryer & TXV, along with a good flush on the lines & evaporator.
