Year: 1995
Make: ford
Model: E350
Engine Size: 5.9
Ambient Temp: 75
Pressure Low: 39
Pressure High: 260
Hello. Im getting 60 degree's discharge air and the air flow doesn't feel to strong in my ford van. I hung a sheet behind the seats.
If the air temp was 45, the cfm might be sufficient, but I have a two fold problem maybe. Lack of cfm and something in my AC system not performing. All the components are clean on the outside. My condenser is behind my intercooler.
I disconnected my heater core with no change in discharge air temp.
After a drive to test if isolating the core helped, I found it was idling at about 50 psi low side, and dropped down to mid 40's when I revved the engine to 2000 rpm. My red line is about 2700 rpm.
At first I thought I over charged it because I was at 40 psi at idle when I charged it, but now wondering if my compressor is tired as I heard it making some intermittent wobbling noise's I'm not used to hearing especially at idle. I did not check the high side psi at that moment.
Do compressors loose suction as they warm up if going bad?
Maybe I should never have left the system empty for a year while I rebuilt the engine? But I had the same dismal performance before the rebuild.
This is a repowered van which used to have a gas engine and the ford compressor was used. Most of the time I'm cruising under 2000 rpm. Do diesel AC clutch's have smaller pulleys to compensate for the lower engine rpm?
Where should I start to look if everything is clean and all fan speeds work? I also have confirmed the outside air damper is closed for recirculation when on Max AC.
Thanks!
95 E350 6bt/nv4500
Edited: Thu June 11, 2015 at 12:30 PM by rebar
In AZ we never could get these vans to cool well. Poor insulation and a ton of heat from the engine bay creates poor a/c conditions.
Ok, nothing about that van is "normal".
You stuffed a Cummins in it. The subtle "repower" in your title goes right by many.
To start with your high side is way too high for 75f ambient. Mounted behind the intercooler is a lousy place for the condensor - it was designed for ambient air flow temps.
A great mechanical fan with a good shroud might help with the condensor issues. What do you have for a fan now?
The second issue is that the blend & direction doors on that vehicle run on vacuum. A common failure is a bad check valve on a gasser - you get most of the air on the defroster vents with low or no vacuum. Do you have all of the vacuum hoses connected? On vehicles that old, Ford used nylon spaghetti lines in places. After 20 years they get brittle & crack - did you move a bunch of lines near the A/C box during the swap?
Finally, Ford trucks & Vans of that vintage are well known for sucking up dirt from the passenger footwell. Blocked evaporators are common. Pet hair, gum wrappers, leaves, a dead mouse - I have found all of that and more in E/F series evaporators.
Does the high side drop like a rock if you mist the condenser with a garden hose? If so, you have an inefficient condenser/condenser airflow.
Edited: Mon June 15, 2015 at 6:47 PM by Dougflas
http://i640.photobucket.com/albums/uu127/re-rod/2ED7A436-B310-47E6-A586-6A660F84B55C_zps6zacdkx6.jpg
95 E350 6bt/nv4500
I would flush everything being reused, replace the compressor, OT, and accumulator.
IMHO, the aerosol flushes contain just enough solvent with dismal flow to be a solvent injector; not a flusher. The reason you did not see any metal particulates when you flushed (if they are there); is this type of product cannot produce the liquid flow velocity to move them. In most cases the spray cans just contain a cheap white solvent (aka mineral spirits), which is a decent solvent for mineral oil, but not so with PAG or POE oils used with R134a.
The air blow to blow out recommended solvents is usually a full blow (direct air line connected) with dry air (filtered) for 20 to 30 minutes. If any solvent is running out or solvent mist is still present, more air blowing is required. The vacuum process can only remove some minimal trace residues, excessive solvent will dilute the vacuum pump oil and possibly damage the vacuum pump.
I flushed both evap and cond with lacquer thinner in reverse and saw a few black deposits come out of the cond. Both are installed and I'm on my second evac. After a few more gas flushes, in the low and out the high, Ill pull vacuum for the last time and draw the oil in. If that's ok.
New accumulator, Orifice tube , O rings , oil and blower.
My question is about charging now. Ford says 44 oz 134a refrigerant. But can I add a few extra oz and expect it to stay in the accumulator? Do I need to be exactly 44 oz or is a touch extra for deminimis gauge removals and what not a good idea?
Thanks!
Do I draw my oil into the accumulator?
95 E350 6bt/nv4500
Edited: Thu June 25, 2015 at 2:15 PM by rebar
Did you drain the compressor? New Compressor? Either way, pour oil in to the suction side of the compressor with the system open. Rotate the compressor shaft (clutch plate) 6 to 10 revolutions to clear the cylinders.
Close the system up and evacuate. 44 to 46 ounces of refrigerant should be fine.
I prefer to charge the bulk of the refrigerant as liquid in to an evacuated system through the high side, with the engine stopped. You can push more than 50% of the charge in this way before you ever start the engine. With no risk of degreasing the compressor, since the discharge check valves will only let the refrigerant enter the condensor from the high side port.
Once you have the bulk charge in, close the highside handwheel on your gauge set before starting the engine.
Once the engine is running start the compressor,and finish charging through the low side as vapor. Let it cycle, do NOT jumper it to run full time.
You will only have it open for a few minutes. Vacuum it back down. You want to pull the vacuum on the oil to remove any trapped air or moisture in the oil.
The reason you turn the compressor by hand for 6 to 10 revolutions is to prevent slugging it. This moves the oil through the compressor to the discharge line. The inside of the compressor will be well coated at startup, but the hand turning clears the cylinders of excess liquid.
So what is your ambient temperature? Vent temperature?
30 & 190 at idle sounds ok to me, depending on ambient temp.
Set the cabin fan on highest speed, and open both doors. run the engine at 1500 rpm & check the pressures.
1) Why did you add refrigerant? Pressures were good.
2) This is the OEM Ford compressor. How many miles are on it? How is the belt tension applied?
Is the compressor able to turn, is the static pressure holding? If it seized up or you find the front of the compressor got hot enough to melt the seal and cause a leak, you would replace the whole unit.
You really need to do something about the condenser. When you're driving, the intercooler will be making heat, so it's still not good. I think the 95 had a piccolo condenser-- a slight improvement over the "old school tube and fin" but a true parallel flow mounted up front is really what you want.
Compressor idler bearings fail. Sometimes with no relationship to the rest of the system. It is even possible the compressor had 200k on it.
Throw that chart in the trash. The charge weight on a CCOT system is what you should use. Too much additional charge backs up in the condensor, and drives pressures up, while decreasing cooling.
Higher pressures don't improve cooling. The low side pressure is controlled by the cycling switch at low ambient temperatures. The low high side you posted is actually good news. It means that the OEM cummins fan is moving quite a bit of air, and that you may get away with the condensor behind the intercooler.
If the system still has pressure, you can put a bearing in the pulley. Sounds like you are not afraid of a little mechanical work.
Just put the charge back to 45 ounces. 25 on the low side makes cold air.
The price for a genuine SKF is not bad.
Chinese bearings are cheaper, but some say they are not as good:
VXB bearings 55x30x23
The clutch is ok if the coil is not shorted, open, or damaged. Re shim it to the minimum gap. A clutch is fine at .010 inch gap as long as it does not hit in one spot.
Yeah, that one is dead. Good news is an NEW FS10 is around 200 bucks with a clutch.
FS10's do ok. If they are working hard on a big vehicle like a van, they will not last as long as they do in a Mustang.
Without big upgrades to the condensor, and adding a second evaporator, your best choice is to keep the stock system.
Now, if your motto is "go big or go home", then yeah you can build a killer system. How far do you want to go/
