Ac problem
PITT412 on Thu May 28, 2015 7:15 PM User is offline
Year: 2003
Make: neon
Model: sxt
Engine Size: 2.0
Hi everyone,
new to the forums. I just finished installing a new ac evaporator core a few days ago, everything went well, no leaks and ice cold air. The only problem I am having with the ac is when I accelerate the compressor kicks off for a few seconds. I only added one 12oz can of r134 to check for leaks before adding the rest, so I know it is not overcharged. When I hook the gauge up to my low side port and and increase the rpm over 1,500 the pressure shoots up high then the compressor cycles off for a few seconds. What is causing this problem?
HECAT on Thu May 28, 2015 8:35 PM User is offline
No disrespect intended, but right now you are causing the problem; its undercharged.
You will need to vacuum and charge with full amount. Then provide the low and high side pressures.
PITT412 on Thu May 28, 2015 8:43 PM User is offline
In the past when my system was undercharged the compressor would just cycle rapidly and the pressure would stay low. Now, when I accelerate the pressure increases alot then the compressor cycles. I believe the high pressure switch is turning it off. If the system is undercharged why is the pressure spiking so high when u accelerate? At idle the compressor stays on and delivers cold air.
I did not vacuum the system, but should have. I will probably replace the Accumulator, flush the liquid line/orifice tube and vacuum the system.
Edited: Thu May 28, 2015 at 8:47 PM by PITT412
GM Tech on Thu May 28, 2015 9:50 PM User is offline
You have air in the system causing the pressure spikes-that's what air does- always pull a vacuum!!!
HECAT on Fri May 29, 2015 5:05 PM User is offline
Yup.
