is this normal for a Forenza
coopercraige on Mon May 25, 2015 11:52 PM User is offline
Year: 2007
Make: Suzuki
Model: Forenza
Engine Size: 2L
Ambient Temp: 80
Pressure Low: 30
Pressure High: 210
I was curious if anyone has experience with this model. Output temp on "high fan / center vent / recirc" is low 50's at idle. Is that reasonable for a Forenza ? Low pressure reading seems low to me.
High side seemed pretty much spot on given the 80 degree ambient.
thanks,
Craig
Cussboy on Tue May 26, 2015 2:07 PM User is offline
Actually, if those pressure readings are at about 2000 rpm, then the high pressure reading seems a little low to me.
TRB on Tue May 26, 2015 2:22 PM User is offlineView users profile
Are you sure you have the proper amount of refrigerant by weight?
coopercraige on Tue May 26, 2015 2:48 PM User is offline
I haven't done an evac and recharge yet so no chance to weigh any freon. The front end suffered minor damage and the condenser was bowed a little but seemed to straighten out ok without losing freon. I was just checking readings before it gets too hot here. pressures were all taken at idle. Should I be testing at 2k ? I've been spoiled by my S10 pickup that cranks out 38 degree air. Maybe 50 is all this one can produce.
Craig
