Lines freezing up
jockwalker on Tue April 07, 2015 2:25 PM User is offlineView users profile
Year: 1967
Make: Chevy
Model: Camaro
Engine Size: 327
Refrigerant Type: R12
Ambient Temp: 50
Pressure Low: 30
My 67 Camaro is cooling fine and temp is where it should be. However, After driving in city or highway speeds, the lines around and including the POA valve, are all frosted up. Normally I would think I was low on R12, but just left the shop and freon is fine. Any thoughts? Thanks
GM Tech on Tue April 07, 2015 3:06 PM User is offline
The freon is fine?? How did they know? Only way to know for sure is to extract and weigh the refrigerant- if not to factory spec- then look for leak- fix it and evacuate and recharge to factory fill specification- by weight, not by pressure.
jockwalker on Tue April 07, 2015 4:35 PM User is offlineView users profile
They said the sight glass in the dryer was clear, the low side pressure was 30, and temp was fine, the freon was ok. They did an extensive check for leaks and nothing showed up. This has been going on for at least a month and there has been no temperature drop. I am not an a/c guy. That is why I am posting. Thanks!
