97 camry 2.2L flashing ac light and clutch not engaging
cleonard on Wed November 05, 2014 1:36 PM User is offline
Year: 1997
Make: Toyota
Model: Camry
Engine Size: 2.2L
Refrigerant Type: R134
About 140k miles on the car and it's always been in warm southwest environments so the AC gets a workout. From what I've read 150k miles in a hot place seems to be the life expectancy of this AC system.
AC was working great, but there was a small amount of rattle type noise from the compressor. Nothing really loud and just barely noticeable from inside the car. One day the AC quit. Upon pressing the AC button it would light up for a few seconds and then start flashing. Looked like the compressor tried to engage as it turned just a little. System is full of Freon and I can turn the compressor by hand.
Read about relay issues so I took a look at the inside of the OEM relay. It did not look good. Tried a generic replacement and the AC came back to life. A week later it quit again. Upon initial activation I can hear the clutch click, but it slips massively and the compressor makes about 1 turn before the AC system gives up and starts the flashing light.
I'm thinking that the clutch is done and needs replacement. There is zero space in the engine compartment so the compressor has to come out. Since a whole new compressor with clutch is only a little more than just a clutch I'll replace the compressor. Since it was making some noise should it be treated as a failed compressor and go with a system flush, new condenser, TXV along with the mandatory drier? Could I just get away with replacing the compressor and drier with some make up oil? If so how much make up oil?
Before spending any $$$ on parts I do plan on putting 12V from the batter to the clutch directly to make sure that it still doesn't work. It seems like a straightforward case of a clutch no longer engaging properly, but I like to be sure of that before buying parts.
wptski on Thu November 06, 2014 7:46 AM User is offline
Try the direct feed from the battery first. If it stays engaged you have a wiring issue. It's stranded wire so if there is a place wire some of the strands are broken, it won't be able to handle the current needed to operate the clutch.
GM Tech on Thu November 06, 2014 8:44 AM User is offline
The system is detecting the slip and shutting it down, so you won't burn out the pulley bearing and be walking home.....it works quite well- so it is new compressor time.
mk378 on Thu November 06, 2014 9:32 AM User is offline
Be very careful jumping the compressor, if it does run when the condenser fans are not on it will overpressure. And you've disabled the pressure switch.
Cussboy on Thu November 06, 2014 1:48 PM User is offline
I'd replace the entire compressor, like you stated, because you don't have access to just swap on a clutch. Since the compressor has not seized, no need to flush, and doubt that you'd even need a new drier.
I'd measure the volume of oil remaining in the old compressor, and use that as a guide for the new compressor. I just replaced a compressor with new in my 1988 Mazda truck, and new compressor contained only 1/2 oz. oil. So I added what I expected to be the correct amount. My compressor had seized up, so I flushed lines, condenser, and replaced its drier, your situation is way different.
