Year: 2003
Make: Mazda
Model: Protege5
Engine Size: 2.0L
With fan on "1" the AC and blower work. AC light is on, compressor is working, and air is cold. Fan blows slowly.
Moving fan speed to 2+ the blower works (fan increases speed) but AC stops working (AC light goes out, compressor shuts off). Cycling the AC button does nothing.
Dropping fan speed back to "1" causes the AC light to come back on and all works fine as long as fan is on "1".
Unfortunately, this low of fan speed doesn't cool the car well in 97 degree summer.
PS: Replacing the blower motor resistor didn't solve anything. Did that based on bum advice.
Thanks in advance for your help and sorry if this is covered elsewhere in the forum. I couldn't pull up anything in search.
Is one of your choices in the fan selection speeds "off"
If so, your fan speed is the master on/off switch for the a/c compressor- and is wired in series with the a/c light- so I'd suggest, that the fan speed selector switch has bad connection on any speed other than "1" and needs replaced.
It's probably the blower switch. In the old-fashioned resistor/switch systems, the switch usually has a separate circuit dedicated to enable the compressor on any setting other than off. Also it could be a bad ground.
A bad resistor will not run the blower on low but it will work on high, so that was bad advice.
Edited: Mon September 01, 2014 at 8:32 PM by mk378
