Year: 1950
Make: Studebaker
Model: 2R5
Engine Size: 350
Refrigerant Type: 134A
I have an under the dash kit model 10020 and I am trying to wire it up. The truck is a 1950 Studebaker with Corvette running gear. The under dash unit has 3 wires. One I am sure is the ground for the motor. Then there is a black wire and a blue wire coming from the unit. My question is which wire goes where. I have a painless wiring harness and there is a wire labeled AC/heat power. Please help. Thanks in advance.
need more info. I would think that one wire is the 12v supply and the other goes to the clutch. The 3rd should be ground. You need to trace them out.
