Compressor install goof
DaveV on Fri July 18, 2014 11:20 AM User is offline
Year: 2005
Make: Ford
Model: Escape
Engine Size: 3.0 V6
Ambient Temp: 1
Pressure Low: 2
Pressure High: 10
Hi all, newbie here from Boston. The clutch bearings in my AC compressor pulley went south, so being part of the serpentine belt system I had to replace it. Here is Boston AC is not critical, unlike Arizona. In my other vehicles when the AC died I just let it be, as I really didn't need it, but on this vehicle it is critical to the belt system, so I just did my very first AC work in all my years. The GOOF I just realized I made was that after adding the 7oz of PAG46 to the compressor, I was supposed to rotate it 10 or 20 times, so I just spun the pulley by hand.. Now I find out that I should have got a special spanner wrench to rotate the clutch properly. I didn't.. - SO my question is, can this damage the new rebuilt compressor I just installed by not doing this rptation properly? Any and all feedback is appreciated!
alan73 on Fri July 18, 2014 1:25 PM User is offline
you can usually turn them by hand grab the front clutch hub and turn it the main concern is that its not liquid locked.
HECAT on Fri July 18, 2014 2:00 PM User is offline
We did not do it years ago. Only because of the understanding that it is a real risk of failure has it become a common practice today. So did you start it up? If it is not "hammering", you are probably OK. If you have not started it yet, find a way to do it; so you can eliminate the risk.
Cussboy on Fri July 18, 2014 4:57 PM User is offline
Couldn't you have just used a shorter serpentine belt and bypass the compressor altogether?
Edited: Fri July 18, 2014 at 4:58 PM by Cussboy
GM Tech on Fri July 18, 2014 7:06 PM User is offline
absolutely every commpressor ever mounted the first time on an engine at the car assembly plant was initiated with a belly full of oil- the entire system oil charge-when the engine starts for its first time- so you are worried that you did something different than the assembly plants??? fear not.....it happens thousands of times a day-spinning the pump is an old wives tale....
wptski on Fri July 18, 2014 11:01 PM User is offline
Are you sure that they don't come with oil installed, plugged and maybe rotated where/when they are assembled?
GM Tech on Sat July 19, 2014 7:39 AM User is offline
I've been in almost all GM assembly plants in North America and some overseas- from 1990-2009-representing Delphi/Harrison never have I seen a person rotate a compressor- and yes the entire oil charge is the responsibility of the compressor manufacturer- so it is ALL in the belly of each compressor- started and engaged when commanded on at first engine start--I've stood and listened for slugs at engine/ A/C start-- no big deal!
Note- the only exception is rear systems- where the assembly plant will add 3 ounces for a rear system- automatically through the charging station.
Evacuation is 15-30 seconds- fill is within 5 seconds- they use a hydralic "syringe" that draws back said amount of refrigerant and pushes it into the evacuated system.
Evacuation tank -100 gallon or more is pumped down continuously by huge vacuum pumps- then attached to high side on car for the 30 second period- then it shuts off vacuum- looks for vacuum decay in 8 seconds- if none- then the big ram pushes in the refrigerant....all while car is moving down the line- high side coupler detaches automatically upon green light indicator at end of cycle.
wptski on Sat July 19, 2014 9:09 AM User is offline
If the oil is the responsibility of the compressor manufacturer, maybe there is a rotation process during the oil fill? Is that Harrison as in compressors? If so, what's in the oil fill process, a rotation??
Thanks for the A/C assembly line procedure as I've always wondered.
GM Tech on Sat July 19, 2014 8:25 PM User is offline
NO rotations at compressor manufacturer- guaranteed- I worked at Delphi Harrison- (Delphi Thermal, Harrison Radiator, Delco Air) as a field engineer....
