I've got a leaking high pressure line (R-134a) after the dryer that is 10' long and has multiple bends. There's a short length of barrier hose near the dryer, with a beadlock #6 female O-ring connector on it, and it's that hose that's leaking. After the one foot length of leaking hose, there's another 9' of 3/8" steel tubing winding around the engine compartment before passing through the firewall to the evaporator. It's extremely difficult to remove that hose system due to all the tubing bends and length, so I want to cut off the steel tubing/leaking hose and replace with hose from the cut off tubing to the dryer.
My problem is how to connect to the cut steel tubing. Most people recommend that I not use a compression fitting with R-134a. One shop suggests making up a hose that has the same beadlock #6 female O-ring connector on it to connect to the dryer at one end and a weld-on 3/8 beadlock fitting at the other end. Then they suggest I silver solder/braze the connector onto the cut steel tubing after the hose is made up. I have room to make the braze, but I'm worried about the heating needed to braze after the hose is already crimped on. Won't the heat damage the barrier hose? All the weld-on fittings I can find are very short, so there's not much room for a good heatsink. I don't have room to get the crimper in after brazing, so I can't do the crimping after the brazing.
I'd like to weld on a male insert connector to the steel tubing, then put female O-ring connectors on both ends of the hose. That way the hose isn't exposed to heat during brazing/silver soldering, but I can't seem to find a weld-on male connector that the female beadlock would connect to.
I've also considered trying to flare the steel tubing, and using a flare connector on the barrier hose, but again, I can't seem to find the correct fitting. Plus, I've never flared steel tubing with my tools - only aluminum and copper.
Any suggestions on how to deal with this?
Thanks a lot!
lok-ring tool
Swagelok fitting.
To provide a little more detail, swagelok fittings need to match the tube material. If you have a Steel line that is 3/8" OD as described this would be the fitting:
Swagelok fitting
Locate an accessible straight section of that tube, and cut it. Then install the double ended compression fitting. At that point, you can remove the line segment with the failed rubber hose, and make appropriate repairs - with no underhood torch work.
The fitting may be disassembled & reassembled without affecting the seal integrity. As Cussboy pointed out, they are used for helium at pressures over 2,000 psi without leaks.
B
Thank you for the recommendations. I really appreciate the replies. I'll go with Swagelok.
yes. I remembered the name incorrectly but you have the correct info.
