A6 and double lipped seals--confused
tab a on Thu June 19, 2014 6:55 PM User is offline
I've read through all the A6 threads I can find, and am still confused. Can you actually SEE 2 lips/edges on the double lipped seal? From all the pictures on this site, and others, I've only ever seen one lip. And at least one poster suggested that Chick's picture of the DLS in the A6 shaft seal change thread was actually showing a regular single lip seal. Do the single and the DLS look essentially the same, without an extreme close up view?
Thanks.
GM Tech on Thu June 19, 2014 10:14 PM User is offline
Yes, both lips are visible, one is rubber the other is teflon
tab a on Thu June 19, 2014 11:14 PM User is offline
Hmmm....pretty sure I've never seen a picture of that. Is the Teflon white? Is it on the clutch side, or the compressor body side of the rubber lip?
Is that really the DLS next to the ceramic seal in the picture in this thread?
http://www.autoacforum.com/messageview.cfm?catid=20&threadid=18683&FTVAR_MSGDBTABLE
Or is not possible to tell?
Thanks again.
GM Tech on Fri June 20, 2014 7:38 AM User is offline
Teflon is black on clutch side of seal- rubber lip is less obvious on compressor side-
Yes that is a double lipper in the thread
tab a on Fri June 20, 2014 10:08 AM User is offline
OK. Last question--I hope! Can you see both lips in the picture--I think maybe I can?--or would you need to turn the seal over?
Thanks again.
CorvairGeek on Fri June 20, 2014 12:49 PM User is offline
You'll will see it if you turn it over. Very obvious when you can see one in person.
Jerry
