Year: 1991
Make: gmc
Model: suburban
I am replacing my compressor and I noticed the new compressor has a plug where the pressure relief valve would go. I removed the plug but the hole has a machined recess that fits an o-ring. the old compressor has a flat machined face for the PRV. The PRV will not screw in all the way and seal on the new compressor due to the recessed area on the mounting surface. Can I just put the plug back in and delete the PRV on the new compressor?
Thanks in advance for the help.
I believe you are referring to the high pressure cut-out switch port- the HPRV is a 3/8" threaded hole next to the switch cavity- and they were always present and never used a plug. Yes, you can run without the switch port switch- if the original was without one-- but somewhere there is a rule that with 134a converion- there must be a HPCO switch.
ok. thanks. ill get it done right then.
