Year: 2006
Make: Saturn
Model: Vue
Engine Size: 3.5
Well I have an issue that I can figure out and rather throw $ after $ at it I want to see what it could be.
When I first bought it it was back in 2008. About a year later I had A/C issues and they(dealer) replace the compressor and charged the system. A month later it did it again and they had to replace the evaporator, All under warranty thank God!
Fast forward to 2010, and same thing. Took it to another dealer and they had to replace the compressor AGAIN!
Here we are at 2014 and it is doing the same thing. It would cool only when RPM's above 1.5. At idle it would not be cool at all.
Now it won't even do that. The compressor does kick on and clutch engages. The high and Low side you can see from the pics. This was before I replaced the Control Valve on the back of the compressor.
CAR OFF 87F 60% Humid
CAR ON
I replaced the valve but still the same thing. Here is a pic of the old one on the right and new one shiny brass color:
https://www.dropbox.com/s/4tyaeq2ja86rgua/2014-05-25%2014.54.56.jpg
https://www.dropbox.com/s/8yixw23wipvhtw0/2014-05-25%2014.54.12.jpg
https://www.dropbox.com/s/bsowox59zf6v0p5/2014-05-31%2013.29.01.jpg
It does not look like it wants to post pics.
50 psi when off seems a little low to me at 87F. I believe my system probably is around 80-90 psi on both high and low sides before engaging the compressor. Leaking? After 3 compressor failures, did they ever replace the condenser? I'd imagine it would be plugged up pretty good if any mechanical damage to the compresor resulted in fragments entering the condenser.
I agree, there's hardly any refrigerant in there. You should have static pressure of about 90 at that ambient temperature. Variable compressor systems must be fully charged by weight before you can evaluate performance. They do strange things on a low charge.
I pulled vacuum on it for an hour and then let it sit for and hour and it stayed. I added 28 oz to the system and now it is 90/90 off and 50 100 on not blowing cool at all. Compressor does kick on.
I think I might just order the whole kit. Compressor, drier, txv, oil, and orings. $216. That should about do it I hope. If not a gallon of gas and a match.
This case just screams that the condenser is full of metal shrapnel from previous compressors. If it was my car with that history, a proper flush of the entire system AND a new condenser would be at the TOP of my priority list. Given the history, a new TXV is probably in order as well. If the compressor is unable to pump up the high side pressure (which appears to be the case from the photos and description), it would get replaced as well. New drier goes without saying, and orings are just cheap insurance against leaks.
I just ordered the condenser as well. I was thinking it might be messed up because of the smaller holes it has to go through.
Just make sure you thoroughly flush any components you're re-using - the lines, evap, etc.
I will be reusing the evap and one hose. Should be an easy flush. After loaning out my tools to my son and friends I had to go buy some new ones. Figured 50%+ additional 15% off Gearwench is a good price to go with. All my parts should be in by Friday at the latest so until then I have to suffer in this Florida heat.
Would 200 psi do it or I have 5 scuba tanks at 3000 psi adjustable.
