Year: 2005
Make: Dodge
Model: Grand Caravan
Engine Size: 3.8
Refrigerant Type: R134
Ambient Temp: 75
Pressure Low: 70
Pressure High: 70
I need a little help with diagnostics.
Static pressure 70psi. Clutch engages, engine loads down a bit as normal, no odd noises from compressor. Pressures don't move at all, not even a little difference between hi and lo.
Does this make sense? Can the compressor be shot in a way as to make no noises and not put out even a little pressure/suction? Any way to diagnose for bad compressor vs. something else in the system?
Any hints would be appreciated, thanks.
Are the hanwheels of your guages closed?
Haha, no, they're on. I actually watched the pressures both go up about 5psi as I ran the car in the garage and underhood got hot.
The handwheels must be kept closed to take pressure readings. Opening the handwheels allows refrigerant to flow through the center section of the manifold, which will cause incorrect readings. They should only be opened when you're doing something with the yellow hose. But with that said, pressure should still move at least a little when the compressor starts.
Sorry, I misread that. Yes the handwheels are in the position where they are NOT connected together or to the charging hose.
OK, just went and made sure the manifold doesn't have a leak. Gave it a quick shot of 134 to the low side, that side gauge jumped, the other stayed put. So no internal leak.
