Year: 2001
Make: Chevrolet
Model: 2500 Hd
Engine Size: 8.1 L
Had to replace my service port valve cores. I can't read the label under the hood and didnt see an 8.1 liter listing on my link to the oil and freon capacities chart.
My favorite link ever.
http://www.autoacforum.com/speclisting.pdf
Capacity listing
Enjoy
Edited: Fri September 20, 2013 at 8:07 PM by Jag987
That's the chart I looked at. I didn't see a listing for my truck.
It says all engines, the only difference depends on what compressor you have. The other thing that can be done, although I have found conflicting information, is to go to napaonline.com and look up some Ac parts there. It will pull up the oil to use and usually also has listed the amounts to use in the comments under the oil. Hope this helps.
I guessed it was a Denso compressor. Seems like all the light duty trucks I have worked on had the HT6. I put 29 oz in. Seemed to work good.
