Building bench A/C units.. anyone done it?
Leggie on Tue September 03, 2013 7:24 PM User is offline
I was contemplating building a full scale emulation unit built on a pallet, but I am not sure what I would need to use for a power source.
I read a journal published somewhere that some setup needs about 7hp of input.
Variable displacement compressors work by increasing the torque imposed on the shaft. So, a 10 hp engine may produce 10 hp at the rated speed, but if the engine speed was dropped and compressor increases the displacement, would it still keep up or do I need to vary the speed with something like hydrostatic control?
GM Tech on Tue September 03, 2013 8:59 PM User is offline
If you just want to demonstrate how it works- I built one once where I ctanked the compressor- used a copper coil for evap and another copper coil for condenser- and a a capillary tube for the orifice I used a used compressor so it would not be too tight to turn crank- - the evap side would actually frost- had gages on top- pretty neat- I have photo somewhere
Edited: Tue September 03, 2013 at 9:43 PM by GM Tech
Leggie on Mon September 16, 2013 10:48 AM User is offline
No, I need a realistic system with different valves in place, so I can simulate various problems to create the symptoms.
iceman2555 on Mon September 16, 2013 12:35 PM User is offlineView users profile
There is already a custom unit in production. Includes a complete AC system with dash that is totally functional. I shall try to locate the vendor and post back to you. The unit is quite extensive in it's ability to perform and allow for various failure modes for training purposes. If memory serves me correctly, the unit was app $25k. Included many parts that were constructed of a transparent material so that the actual function of the part could be visualized. It is an orifice tube system. Very impressive display.
iceman2555 on Wed September 18, 2013 12:14 PM User is offlineView users profile
Check this web site for a stand alone unit. I have seen this is practice and it does an excellent job for training.
http://www.merced-ac.com/
mk378 on Thu September 19, 2013 8:09 PM User is offline
That looks neat. I've seen a complete scale model PWR nuclear power plant made almost entirely of glass-- it must have cost a lot. They could demonstrate exactly what NOT to do at Three Mile Island.
