Compressor / system troubleshooting Pages: 12
Solar4 on Sun September 01, 2013 12:32 PM User is offline
Year: 2007
Make: Acura
Model: TSX
Refrigerant Type: R-134
Ambient Temp: 105
Pressure Low: 130
Pressure High: 130
AC has been working normal. My wife is driving home yesterday and it quit cooling rapidly. Turns out the compressor is not engaging. The electric condenser/ radiator fan engages with the AC selected ON. Same result when bypassing the pressure switch on the high side; but no compressor engagement. Compressor turns freely by hand. Hooked up gauges and the system is equalized at about 130psi. Don't know exactly how much freon is in the system but the sight glass appears normal and I feel some freon escape while hooking up gauges.
Is there another component that controls compressor cycling such as a low temp switch on the evaporator? Can you jump it to see if the compressor will engage? Is there a chance that it's the compressor/ clutch? Looking for any troubleshooting advice.
mk378 on Sun September 01, 2013 2:10 PM User is offline
Check if power is reaching the compressor coil when it should. If not, check the fuse and relay, which are usually in a fuse box under the hood. If the compressor has power but doesn't engage, the coil may be open or the gap too wide. The controls inside the car are probably OK since the fans are starting.
Jumping stuff on a modern car tends to get expensive. Test by probing instead of jumping.
GM Tech on Sun September 01, 2013 6:04 PM User is offline
if it runs after an all night sit- and quits after engine gets warm- you probably have a too wide air gap- if so, remove a shim from in behind clutch driver...
Solar4 on Mon September 02, 2013 12:37 AM User is offline
Where is the compressor coil? I am reading .091 volts on the positive lead to the compressor after the AC button is selected on. Using the same ground I read 12+ volts on both positive fan leads (ignition on car not running). Fuses were good. Pardon my ignorance, but how do I find the relay? Sounds like I might get somewhere if I could locate the compressor coil and relay!
Jag987 on Mon September 02, 2013 12:56 AM User is offline
The power lead you are getting .091 volts on, is that on the front of the compressor where the belt turns it? If so, that is the coil.
Solar4 on Mon September 02, 2013 2:06 AM User is offline
It is bolted onto a junction on the compressor body (where I read voltage) and then continues on to the front of the compressor. Should it read .091V or 12+V?
Jag987 on Mon September 02, 2013 6:21 AM User is offline
12+. The coil is an electric magnet that sucks the hub on the compressor in when it is activated. It is not getting enough power. What does it read when it is off? I am curious if in fact it is getting any power.
mk378 on Mon September 02, 2013 11:33 AM User is offline
It's normal to read a few millivolts on a circuit that is "off" due to ground potential differences.
There's always a black plastic box somewhere under the hood (usually near the battery) full of fuses and relays. The car's owners manual may mention it. Typically the inside of the cover of the box is printed with a map to what each relay is for.
Edited: Mon September 02, 2013 at 11:35 AM by mk378
Solar4 on Mon September 02, 2013 3:55 PM User is offline
Ok sorry guys, scratch that .091V. That was actually the ground wire so I'm guessing residual voltage. I disconnected the power plug to the compressor and read 5.7 Volts with AC button selected on and key ignition on. With car running I read 6.3 volts. I get the same voltage readings for the power going to the pressure switch. 5.7 and 6.3 volts respectively. I have checked all the fuses and swapped around all the relays: (3 of the same and 2 of the same.)
Shouldn't I be reading system voltage (12+ and 14volts) at the pressure switch and power plug going to the compressor?
mk378 on Mon September 02, 2013 4:08 PM User is offline
You should have either near zero, or 12. Are you grounding the meter properly? Put the black probe on either the battery - post or the engine block.
Edited: Mon September 02, 2013 at 4:11 PM by mk378
Solar4 on Mon September 02, 2013 4:21 PM User is offline
Yes, 5.7 Volts with AC button ON and putting black probe on either battery - post or engine mount that has large ground straps.
wptski on Mon September 02, 2013 7:29 PM User is offline
I assume that you double checked your meter right on the battery?
That very low voltage considering that the load from the clutch coil isn't even on it. Find which relay powers the clutch and if the same value/number is used in another position to swap with. If not, pull the relay and check if you have 12V coming into the relay. There should be two, one powers the relay coil and the other supplies 12V through the relay contact when closed to the clutch coil.
Solar4 on Tue September 03, 2013 1:47 AM User is offline
Yes, the meter indicates about 12.4 battery volts. Leaving the black probe on the negative Batt post and putting the red probe on either pressure switch or compressor power plug indicates 5.7 volts. I counted 5 total relays. Two of the same and 3 of the same. I swapped all 5 relays into different positions (of same P/N) and still no compressor engagement.
Sounds like I need to check the relay source voltages.
Edited: Tue September 03, 2013 at 1:52 AM by Solar4
mk378 on Tue September 03, 2013 8:21 AM User is offline
The pressure switch is possibly a low voltage logic - level circuit. Are you sure the wire you're testing on the compressor goes to the clutch coil under the pulley? If you unplug the compressor you should measure 3 or 4 ohms through its coil circuit to ground.
Solar4 on Wed September 04, 2013 1:05 AM User is offline
Well I can't seem to upload a picture from my device to the thread. The link below is a picture of the compressor's plug. It has three wires. Let's call em #1, #2 & #3 in order from left to right. I cannot get continuity among any single one of the three and ground. The only combination that resulted in continuity was by attaching a meter probe to #1 and the other meter probe to #3. This resulted in 0.2 ohms.
Compressor Plug
Edited: Wed September 04, 2013 at 1:10 AM by Solar4
mk378 on Wed September 04, 2013 8:06 AM User is offline
The center pin (yellow wire?) appears to go to the clutch coil. It should have continuity to ground.
The other two are a thermal switch that should be normally closed between the two but no continuity to ground.
wptski on Wed September 04, 2013 8:17 AM User is offline
If the center wire goes to the clutch coil and the other two are a thermal switch, where's the ground wire at?
mk378 on Wed September 04, 2013 9:45 AM User is offline
One of your pictures of new compressors has a green wire coming out of the clutch coil, that wire goes to a bolt which grounds it to the compressor frame. So the coil circuit should return to ground through the engine.
Solar4 on Wed September 04, 2013 9:55 AM User is offline
Ok, so the coil is open/ bad. Compressor is original- 6 years old and 81,000 miles. Guess I should replace the whole thing? Clutch and compressor?
wptski on Wed September 04, 2013 11:35 AM User is offline
With the plug remove, on the compressor two of three contacts should read 3-4 ohms, if not the coil is open. The only problem is what about the 5.7V that you are reading, something isn't right.
mk378 on Wed September 04, 2013 1:22 PM User is offline
The thermal switch circuit is logic voltages like the pressure switch, in fact it is likely just in series with the pressure switch.
Compressor unplugged, center wire on compressor plug to compressor frame should be 3-4 ohms. Outer 2 wires near zero ohms to each other but open circuit to ground.
wptski on Wed September 04, 2013 2:47 PM User is offline
The OP never read 12V on anything yet as far as I know. One end of the coil is grounded internally? Didn't think they still did such things.
Solar4 on Thu September 05, 2013 2:05 AM User is offline
First off, I want to thank everyone for their input, suggestions and most importantly patience with me! Thanks to you, The problem has been narrowed down to the coil circuit - it's open. Unfortunately the compressor is at the bottom and I will have to remove power steering pump or at least alternator just to make sure it is indeed the coil versus bad power or ground wiring. Haven't had much time other than a few minutes of troubleshooting a day. Once again, I appreciate everyone's help but I gotta give an extra shoutout to mk378! You 'da man!... Or woman if applicable...
The compressor thermal switch is in series with the high pressure switch. Makes sense: high temp and/or high press, shut it off! Verified by continuity of one wire from press switch plug to a compressor plug outer wire. I also noticed that the electric condenser fans would not run unless both the press switch and compressor plugs were connected (closed series circuit). Therefore, I had to jump the compressor plug outer 2 wires (simulating a closed thermal switch) and have the car running to FINALLY read 13.8 Volts on the Center wire of the same compressor plug! The 5.7 volts must indeed be a low voltage logic as mk stated. Seems like it took me forever but I was finally able to prove that the compressor coil (at the plug anyways) is receiving 13.8 Volts+/- of juice when the car is running. Who needs schematics and wiring diagrams?? HA!
So my next question is, (didn't think I was done did ya??) am I gonna have to open the system and replace the the whole compressor and clutch assy? Or can you buy just coils anywhere? The compressor isn't that new but it's been blowing ice cold air down in our 100+ degree weather and I hate to mess with that if I don't have to.... not to mention the cost difference
Edited: Thu September 05, 2013 at 2:10 AM by Solar4
wptski on Thu September 05, 2013 7:53 AM User is offline
It depends on the type of compressor and its location. Some clutch plate require a puller so you need room to use that. Same goes for the pulley, a bigger puller yet that you need room to use and a snap ring to remove first. The coil is pressed on but can be removed using a large screw driver prying back/forth.
To put everything back means room for a hammer, etc.
