Insulate accumulator, yes or no
brimac50 on Wed August 14, 2013 9:37 PM User is offline
Year: 1980
Make: Chevy
Model: C20
Is it safe to insulate the accumulator? Or, by design, ....does it need to absorb engine compartment heat, in order to prevent any liquid refrigerant, from getting back to the compressor?
Thanks.
GM Tech on Thu August 15, 2013 9:09 AM User is offline
The accumulator is designed to suck the gas off the top of the liqud- that is its job to assyre no liquid gets to compressor- many luxury cars do insulate- cheap made cars do not- its a matter of cost- it does help- you weigh the cost if you make 200000 of one model with or without insulation...per year
Dougflas on Thu August 15, 2013 12:29 PM User is offline
Ford used to insulate their accumulators. they were made of steel. And they rusted out causing leaks. Most are now aluminum so no rusting.
