Year: 2001
Make: Chevy
Model: 2500HD
Engine Size: 8.1
Ambient Temp: 87
Pressure Low: 40
Pressure High: 275
Pressures were taken at 1200 rpms and vent temp was cold.
I drove 50 miles from home day before yesterday. On the way home the vent temp started warming up and the volume of air coming out of the vents really decreased. I parked the truck in my shop when I got home and let is sit for a few minutes. When I came back there wasn't much water under the evaporator drain. I started the truck and the air was on and a lot of water started coming out of the drain.
classic freeze-up - run it on recirc- hood up low fan for awhile- does it cycle? does all pipes on low side turn snow white? if freezing- then look into a new cycling switch,
I just checked, and it is cycling. fan on low and ac on recirculate.
It has been unusually humid here lately. Would that cause it to freeze up?
Like any intermittent problem, you have to check when it actually happens (when it is frozen.) The switch can get stuck. If you find it frozen up and the compressor still running, unplug the switch and it should stop. That would confirm the switch is stuck. If the compressor keeps going even then, it could be the relay getting stuck.
