Year: 1986
Make: buick
Model: regal
Refrigerant Type: r-12
Hello, I need to change the Schrader valve on the high side on a 1986 buick regal. Is this a standard valve I can pick up in the auto store used for tires? What is the part I am looking for?
Thank you for the help.
Don't use a tire valve. Ask for an A/C shrader valve. Tire valves have a different kind of rubber than the A/C ones do.
I bought a R12>R134A adapter set and the can adapter was threaded for a core. There are so many different ones out there with confusing descriptions as well. I took the adapter to CARQUEST but had this part number from an online search with me that worked. Core
Edited: Sat July 20, 2013 at 9:55 AM by wptski
Im assuming that one should nylog the threads of the schrader before installing?
