leaks but holds vacuum
LDA007 on Mon July 08, 2013 9:43 PM User is offline
Year: 1995
Make: GMC
Model: Sieraa
Engine Size: 305
Refrigerant Type: 134A
Ambient Temp: 85
Pressure Low: 0
Pressure High: 100
Vehicle is a 1995 GMC Sierra 1500 w 5.0L RWD
This vicious cycle has been going on for about three years.
1)Freon will leak out. Some times fast ( a week) other times slow (three months)
2) I will vacuum the system to find it hold a vacuum.
3) I will refill according to manual. ( 2 pounds or 2.5 pounds depending on source)
4) The air will blow cold for a month to 6 months or longer then will lose all the freon. The last time it was lost in about a week.
The last time this happened, I did the following:
I have put about an ounce may be more of oil with dye in the system.
I have changed the o-rings on the back of the compressor. I would change more but the system keeps holding vacuum.
I have put a new low pressure switch on it.
Unrelated but I also changed:
fan belt.
EGR Valve
Spark Plugs
Wires
Distributor cap and rotor
Currently, I again hooked it up to a vacuum pump and after removing the pump it again is holding a full vacuum (at least three hours now).
To my surprise, not a trace of dye. I am using an 18" long florescent UV light. May be its not right.
Any help will be greatly appreciated.
Murphy is faster than I.
GM Tech on Mon July 08, 2013 10:31 PM User is offline
If it is the original compressor- an R-4- you can bet it needs a new shaft seal- and it probably has the dreaded shell ..o-rings leaking-- those big o-rings are flatter than a pancake over time
these are the two most common leak points- I always start by resealing and new shaft seal in compressor- then let it go- it solves 95% of leak issues.--
If you take your clutch driver off- you'll see massive grease build up- most Old R-4 compressorsl have this. also, do you oil sling strips on the underside of hood liner? this is a telltale sign the shaft seal is a gonner..
LDA007 on Mon July 08, 2013 11:23 PM User is offline
I closely examined the compressor and you are exactly correct. A super fine mist of dye is all over it. I barely am able to see the dye. I will replace the compressor. Do I need to change the accumulator and orifice tube? The video I watched shows this step to be tricky. The orifice tube got stuck and on my truck, evidently it's behind the head lights.
Thank you very much for your help. I have been working on this problem for a long time.
Now if I can just resolve the issue with my transmission delaying shifting and no codes showing. But that's another show. LOL.
GM Tech on Tue July 09, 2013 8:26 AM User is offline
I personally don't replace accumulators or OT for a failure mode of a leak--the accumulator will refuse to let go of the evaporator connection and you will tear it up to replace something that doesn't have to be replaced-- OT will be fine....
Been doing a/c jobs like this for 30 years- never an issue not replaceing the A/Ds-- we ran experiments with no desiccant in A/Ds on sheriffs fleets in Texas-- 3 years with no issues---so with r134a the desiccant is not that important...
let the debate begin...just sayin....
LDA007 on Tue July 09, 2013 1:41 PM User is offline
Thanks I may check the OT just out of curiosity but I am going to follow you experiences.
To help in the debate you may have started, it's humid in Texas (I'm in Tennessee). So if a failure was going to happen due to the lack of desiccant, it probably would have happened. I love the "Proof is in the Puddin" examples. Thank you for your help.
