O-ring kit - V5 compressor ?
WyrTwister on Fri June 14, 2013 6:12 AM User is offlineView users profile
Year: 1996
Make: Chevy
Model: Lumina 4 door sedan
Engine Size: 3.1L
I may have messed up . Certainly would not be the first time . :-(
I bought an o-ring & gasket kit for a GM V5 compressor . Is that the correct one for the 96 Lumina ? Does it use the V5 ?
I hope I lucked out and got it right ? I had planned , everything else permitting , to repair the compressor , this weekend .
Thanks , :-)
God bless
Wyr
GM Tech on Fri June 14, 2013 7:29 AM User is offline
All 3.1L engines use the V-5 from that era....You are good tyo go-- I reseal those in my sleep....
WyrTwister on Fri June 14, 2013 12:38 PM User is offlineView users profile
Thank you for the reassurance ! :-)
I had previously replaced the shaft seal . That did not stop it . Then , I did the UV dye and penlite . It is a belly leaker . :-(
Is it necessary to replace the shaft seal , again ?
Thanks again , :-)
God bless
Wyr
GM Tech on Fri June 14, 2013 9:45 PM User is offline
Only if you don't use a seal protector when dissassembling.
WyrTwister on Sat June 15, 2013 6:32 AM User is offlineView users profile
I have a plastic seal protector that came with one of the kits .
Wyr
God bless
