Year: 2002
Make: ford
Model: f150
Engine Size: 5.4
Refrigerant Type: r134
My 2002 f-150 released pressure from Ac. I had gone to the store an I left my truck running an when I came out I heard the pressure releasing from the Ac. I think it came from the compressor. Turned the Ac on an off an it stop. But now its not cooling like it used to. Does any one know what it could be ?
Probably got hot due to bad fan or fan clutch, built up high pressure, so the pressure relief valve did its job. But you likely lost refrigerant and refrigerant oil.
i wasnt aware ac systems had a pressure releif valve. its kinda seems that way, i did an ac recharge for someone and as soon as i started to add a third can the compressor(or the general area) puff really loudly and 134a released for about 1 or 2 seconds. it did this in max air at any rpm over idle.
