Year: 2002
Make: Chevy
Model: Prizm
Recently redid my AC system. Got a rebuilt compressor from Amazon and they didn't ask for the core. old compressor was leaking (from the belly seal) and stop leak was put in. Stop leak plugged up the orifice tube but the compressor still worked/works... just leaks and needs a good home. You pay for shipping by giving me a label.
Edited: Wed April 10, 2013 at 12:57 PM by doctorbee
Another cautionary tale about stop leak failing to stop the leak, but instead stopping up the system leading to total replacement.
The compressor is pretty much a basket case now, it would have to be completely stripped down and every trace of the stop leak removed. If it didn't have stop leak in it it would have been easy to crack it open and replace the case seal o-ring, GM Tech does them all the time.
Very generous of you doctorbee. A+
no takers? currently a rebuilt one is $230 on Amazon.
First off, reducing the photo size that can be seen, like this for example:
Sounds to me like the lesson is that one mans junk is another mans treasure. The OP is kind enough to offer this compressor for free to whoever might need just a replacement coil or something. Shipping to Sweden kills the deal for me though.
NickD, sorry if I came across unclear. the amazon compressor replaced the one currently offered for free. the amazon compressor is in the car compressing happily. this old one needs new belly seals.
With stop leak ran in it and issues. I would hope the only thing someone would use this for is the clutch coil.
From the post, it appears that the "new' compressor is installed on the vehicle and working great....the photo indicates what appears to be an OE compressor. Since you ask for a shipping label, are you trying to sell this old POS or simply giving it away?
Stop leak in your system and enough that it is indicated in the compressor.....can almost guarantee that the recently purchased compressor will not be functioning very long. A restricting in the system will result in a loss of lubricant to the swash plate bearing and the guide rod bearing.....result is an another failed/defective/warranty unit.
Good luck with your repair.
Nick, using air to test is not all that bad....leaks are more easily indicated with an inert gas. When testing in water, add a bit of alcohol to the water. Breaks surface tension and leaks are more easily indicated.
just giving it away.
everything was flushed before putting it back together.
Edited: Thu April 11, 2013 at 6:27 PM by doctorbee
