Year: 1992
Make: Nissan
Model: 300ZX
Engine Size: 3.0
Refrigerant Type: r134a
I just overhauled my complete AC system with new parts purchased from AMA (new o-rings, drier, condenser, expansion valve, hi/low binary switch, ester oil), a complete flush, and recharge. The AC blows cold but now the compressor is leaking from the shaft seal and between where the compressor casing meets.
1) I'm going to replace the compressor with a rebuilt one. Will I have to change out this brand new drier because I'm opening up the system again and it might absorb too much moisture in doing so?
2) Also, I will have to refill the system with oil again and can't measure what has leaked out. Is only way to get the right amount of oil in the system is to flush the entire thing again and refill? Any tips or suggestions for this part?
Thanks in advance for any info given.
Edited: Thu September 13, 2012 at 1:48 PM by ColdZ
Thanks for the tips Cussboy. There is definitely a lot of refrigerant left in the system so I guess that means no moisture went in, just pressure pushing out then. The AC is still very cold just like the day I charged it. I do try to use it sparingly in this summer heat after discovering the leak too.
My guess was also around 1.5oz-2oz having leaked out as well. Just an estimate based on the size of the pool discovered in my garage multiplied by the the amount of days and spilling an ounce of oil on purpose to see how much area it covered
Just a follow up. I picked up a compressor last Friday and rented a vacuum from Autozone the same day. I removed the old compressor, and measured how much oil drained out of it. Then I drained what was in the rebuilt compressor and replaced back what I removed from the old compressor plus 2oz. I then put everything back together and pulled vacuum right away, charged it up and all is well again. It feels good to have an AC system that has been completely overhauled
