Stumped with High low side
Leeroy on Sun September 02, 2012 9:23 AM User is offlineView users profile
Year: 1999
Make: Chevy
Model: Silverado
Engine Size: 5.3L
Refrigerant Type: R134
Ambient Temp: 85 ish
Pressure Low: 120 ++
Pressure High: 200
I am stumped.
About 2 weeks ago I replaced the compressor accumulator and orifice tube on a friends truck. The system worked fine for about 2 weeks. He called and said that it stopped working. I figured I had a leak and told him to bring it back. No leak!!
The low side pressure with compressor running (jumper wire) goes up into the "retard" section of the gauge...somewhere north of 120. The high side goes up to 200-225. Obviously, the compressor is not running unless I jump it. When it is jumped, the air from the vents is cold. I replaced the orifice tube and this had no effect. I put 2 lbs of freon in the system. On a hunch, I put a large blower in front of the condenser and wet the condenser. So much for my hunches, as this had no effect.
Where do I go from here? Break the system down again and re flush? The parts are under warranty from Advanced, so I am only talking about labor, but that sucks too. I just wanna get this thing fixed.
mk378 on Sun September 02, 2012 9:35 AM User is offline
There's no way the air can get cold with those pressures. You must be measuring wrong.
Most likely it is just a bad cycling switch.
Leeroy on Sun September 02, 2012 10:51 AM User is offlineView users profile
I checked my gauges on 2 other cars and they seem O.K..... They only hook up one way. When I "fixed" it a couple of weeks ago they read normal hooked up in the same positions. I am not arguing, just confused. I am not ruling out user error. Is there a way to test the cycling switch? I am jumping at the relay in the power distribution box.
You are talking about the one on the accumulator right????
Leeroy on Sun September 02, 2012 11:23 AM User is offlineView users profile
O.K> I am going out to check the cycling switch. I will jump across and see what happens. I will report back as to what happens. I am going to ignore the pressures for now!!??
Leeroy on Sun September 02, 2012 1:26 PM User is offlineView users profile
Jumping across the cycling switch produced no results. Well, almost none. The engine rpm goes up slightly but the compressor does not engage. Any ideas?
iceman2555 on Sun September 02, 2012 1:44 PM User is offlineView users profile
What is the production date of this vehicle? Does this vehicle have the top mounted compressor or this an HU6 (low mounted) unit. Also, please state why the system had to be repaired and what procedures and a list of all parts replaced.
How was the system flushed, what chemical was utilized and how was the system recharged. Post as much repair/test info as possible. Also please attempt to measure the evaporator and inlet and outlet temps.
GM Tech on Sun September 02, 2012 2:59 PM User is offline
You don't jump across the switch-- you jump the connector that plugs into the switch
efxengr on Sun September 02, 2012 4:52 PM User is offline
gauge valves closed, right?
Leeroy on Sun September 02, 2012 5:11 PM User is offlineView users profile
O.K.....I am officially an idiot. Thanks to all for your help.
This was a 2 stage problem
1.) Blown ignition fuse wiring diagram has it labeled as IGN E. (Yeah thats right a blown fuse). This was the main problem. I checked the AC fuses before I started. Didn't think to check the ignition fuses. Lesson learned. This circuit energizes the AC relay circuit.
2.) I hate to admit this, but since no one knows me I will tell you. efxengr was right. I forgot to close the gauges (color me embarrassed)
Thanks again guys.
efxengr on Sun September 02, 2012 7:35 PM User is offline
I learned that one the hard way.
Just think how good you felt when you closed the valves and it squared up, doesnt get any cheaper than that.
