Year: 77
Make: Chevrolet
Model: Corvette
Engine Size: 350
Refrigerant Type: R-12
I have restored my Vette and it's time to reassemble the A/C system. I have serviced Residential and Commercial A/C systems for many years but am not familiar with auto. My question is: Should I be able to turn the compressor by hand with the clutch engaged? When I bought the car there was no refrigerant in the system so I don't even know if the compressor is good. I bench tested the clutch and it is ok but I can't turn the pulley with the clutch engaged. I would like not to assemble and charge the system if this is an indicator of a bad compressor. Also there was some white/gray looking stuff that came out when I flipped the compressor over. Almost the texture of thick ashes. Is this normal or another indicator of a failed compressor? I did seal the compressor and hoses while storing them to keep out debris.
-Rick
Yes, you should be able to turn over the compressor by hand when the clutch is engaged, or just the center part; oftentimes by hand, but certainly with a socket/bar.
Out of curiosity, I spin compressor center by hand at the wrecking yard, can spin old ones by hand usually. A brand new one should be tighter, but should move with a wrench.
Thanks for the advice! I thought I would go ahead and install it in the car and try to turn it with a socket bar. I also think if got all of the debris out whatever it is and rinsed it out with mineral oil. BTW I still have 2 cylinders of R-12 and would like to use it. 60# I might could spare a charge to test it.
